File permission error 8 while copying of directory
when I execute the above vi for first time, directory copies from source path to target path successfully.
When I tried to execute the one more time I am getting an error as "Error Code 8, Possible reason(s):LabVIEW:  File permission error, NI-488:  DMA hardware error detected".
What was I am doing wrong... or I am missing something?
(5,389 Views)
I am using LabVIEW 8.0
(5,383 Views)
That may have been a bug in 8.0 It works fine in LV 8.6 (just tested myself).
Ben
(5,379 Views)
Hi, Ben
On my local machine it works fine, but when i run this on my application machine (windows machine) i facing this error. One more thing when i had checked the permissions of the directory it is 511. So i am unable to find why this error comes??....
(5,373 Views)
Accepted by topic author Abhi3345
The error was coming is because of the file permission .... some of the files present in the directory are having read-only permission... So when i run the vi for first time it copies successfully and when i tried to run again i was getting error code 8....
 when i change the file permission by setting 511 ... now i am albe to copy the file successfully Smiley Wink
(5,347 Views)
