File path changing my code?
Ok, yeah, I didn't spot that thanks, but even when I change this I still get the broken wire coming out of the loop.
It says that I'm trying to connect incompatible VISA sessions or data types but I can't see how?
Message 11 of 15
(844 Views)
What are you connecting together?  Do you have more than one open reference in your code?  Are they wired together?
Place a probe on the error cluster wire.. it should quickly point to where the mismatch occurred.
What version of code are you using? Can you post the latest one?
RayR
Message 12 of 15
(837 Views)
I'm a little confused by this as well.  I see no broken wires whatsoever when I open your VI.  The Run arrow is not broken.  Here's a screenshot of your code as I see it as soon as I open the VI in 8.5.
Message 13 of 15
(826 Views)
Ok, I think it is sorted, i have just changed the tunnels to shift registers and put in file names which correspond to files on the C drive of the pC I'm running the program from and have no errors. Very strange, not really sure why I was getting the error, there wasn't any data conflict, anyway it's gone now. Thanks for all of your help!
Message 14 of 15
(816 Views)
LOL! Glad you found it. 🙂
It's always the little things that create the most headaches.  🙂
Message 15 of 15
(809 Views)
