File dialog problem
Good afternoon engineers
My problem is simple, I don't have much experience programming this software. In the VI and attached photo of an NI engineer, I have a file dialog that opens a window to choose the path but I want to change it to static, try build path but it sends an error, What I'm looking for is to create a new file in a fixed folder and leave the name dynamic with a control without using a dialog box. Thankstempsnip.png
(3,138 Views)
How do you envision the name being dynamic?
You can easily hard code the path name using a file path constant.
Then use a build path function to combine the path and the "dynamic name".
Currently using LabVIEW 2022
(3,127 Views)
Accepted by topic author TORRESDANIEL
remove the file dialog and replace with build path.
Create a diagram constant on the upper input and a string control on the lower input
Of course you currently need to enter the name before even running the VI. Maybe you want to do a proper state machine instead, do more error handling, etc..
(3,121 Views)
