File and channel selection
Hi all! I am new here. Right now, I have thousands of tdms file. Each of the tdms file have four channels and each channel can displayed in waveform graph.
The problem is I dont know how to bulid a listbox which u can choose the file from and another listbox to select the channel.
Appreciate your help!! THX
(2,953 Views)
LabVIEW comes with Help and Examples.  See the Help button on the Menu Bar?  Choose LabVIEW Help.  Search for Listbox, and look for something with the location "Concepts".  That should tell you about Listboxes, and may even have a link to Examples!
Or you can go to the Help menu and choose "Find Examples".  The best part of Examples is you can (a) run them, (b) study them, (c) modify them (but I recommend not trying to "save" them, but rather copying them to your LabVIEW Data folder where you can modify them safely without affecting the "master copy"), and (d) learn by doing.
(2,930 Views)
Accepted by topic author Alias108
You'll definitely have to learn about LabVIEW programming by searching a bit. This is not very complicated.
"List Folders.vi" to list the *.tdms files in a selected folder.
"TDMS List Content.vi" to get the list of groups and channels.
Property node "Strings[]" of a Ring control to list the groups and channels.
Here is one quick implementation.
Marc Dubois
(2,928 Views)
Thank you, Bob Schor! I am learning a lot from the examples. They are really good for beginners.
Alias108
(2,891 Views)
Hi Marc Dubois, thank you for posting the suggestion. They did what I wanted exactly. Although it is too difficult for a beginners like me, I will my best to understand them. Many thanks again!!
Alias108
(2,888 Views)
