File Path vs Directory Path
I am getting error 117 when I run Create File with Incrementing Suffix.vi.
"Directory path supplied where a file path is required."
What is the difference between a file path and a directory path?
Thanks.
Forbes Black
Lapsed CLAD, LV 5 - LV 2023 (Yeah, I'm that old...)
(11,326 Views)
Directory path is a folder. File path is a file.
For example, a Directory path would be c:\myTest\testSeries1
A file path would be c:\myTest\testSeries1\myData.txt
(11,313 Views)
Just a guess, but maybe they want a file name instead of a folder name?
Bill
CLD
(Mid-Level minion.)
(11,310 Views)
Directory is the folder, file is the file
(11,309 Views)
Accepted by diarmaede
I figured out what I was doing wrong. I am using Create Directory Recursive for the first time, and I am creating a folder when I thought I was creating a file within the folder. I can fix it from here.
Forbes Black
(11,301 Views)
