File Path Control bug - LV 2021
If I use the browse button to get a file, it works OK:
But If I drag the file from Explorer onto the control, I get this:
There's a trailing null in the file name.
This bug is present in LV 2021, but not in prior versions.
(870 Views)
I believe to remember that they had some issue like that with drag and drop in one of these versions and that there was a bug fix release since, that should fix that? Did you try to upgrade to 2021SP1f2? Bug number 1759565: https://www.ni.com/en/support/documentation/bugs/22/labview-2021-sp1-bug-fixes.html
Rolf Kalbermatter  My Blog
(836 Views)
Version as integer comes back as 21018000 hex.  Isn't that the latest version of LV 2021.
(826 Views)
Definitely not f2! The 8 in there indicates that it is a release build. 4 is beta, 2 is alpha and less than 2 is internal test build guaranteed to crash as soon as you look at it. 😀
you can look in the about dialog for the exact version.
(801 Views)
