File Handling in formula node
Hello All,
I am trying to open a file and write some data to a file within the formula node. A declaration like
file *in;
produces this error:
Formula Node:undefined variable.
Error on line 1 is marked by a '#' character: "file# *out;"
How does one do file I/O operations within the formula node?
KB
(3,283 Views)
Hello KB,
it seems you are trying to write a LabView program by
inserting C-code into a formula node... That's not the way it should be.
As far as I know there is no way to open a file inside the formula node. (It's a "formula" node!) So you have to open the file with LabView for reading and/or writing. Use your prefered subVi from the file palette. Perhaps you have to convert the data to a format suitable for your formula node (like string to U8-array).
In my experience it's better to use Labview-code instead of the formula node. In my programs a formula node was always slower than Labview code. So you should think about converting the C-style code to Labview.
(3,283 Views)
Hello KB,
in the help file of LabView you will find a nice table of the whole syntax/commands of the formula node. Just use the context help on the formula node, then "click for more help", then "Formula Node syntax".
(3,283 Views)
