I have written a vi and the first thing it needs to do is delete an existing results file from a previous run. I am trying to use the file delete vi, FIle I/O --> Advanced-->Delete. But it is not working. I get a file error 6 as follows:
Warning 6 occurred at an unidentified location. Possible reasons: LabVIEW: Generic file I/O error.
I know the path is correct, because I use the Dup path output from the Delete vi when I write out the new rersults file.
Hi, One question: Have you closed the file before deleting? I'm afraid that if you work with file and don't close it you will have problems with delete. Use "Functions->File I/O->Close file.vi" before Delete.
The file should be closed, but I will add this to see if it helps anyway.
Thanks, mike
"Oleg" wrote in message news:506500000005000000B0890000-1023576873000@exchange.ni.com... > Hi, > One question: > Have you closed the file before deleting? > I'm afraid that if you work with file and don't close it you will have > problems with delete. > Use "Functions->File I/O->Close file.vi" before Delete. > > Good luck. > > Oleg Chutko.
