FieldPoint Advise vi triggers out of range read when exiting application
I recently upgraded a LV v6.1 application to LV v8.20.
After doing so and getting the application to run, I found that upon exiting the application an error was triggered due to the FPLVMgr.dll attempting to read memory that was no longer there.
By the process of elimination, I found that the offending code was the FieldPoint Advise VIs used in two locations in the application.
I replaced the Advise VIs with FieldPoint Read VIs and then added a timer to the loop. So now I have the same functionality, but I think I read in one of the Help files that the timer in the loop is not as efficient as the Advise in the loop.
Is there a fix for the FP Advise VIs?
(2,455 Views)
Hello lgk,
The FP Advise vi is performing its own loop as well.  If you look at the Advise, you will notice that it just calls some DLLs inside a loop.  Perhaps these functions that the original VI was calling has changed in the latest version of FieldPoint.  I would recommend trying to put down the new Advise VIs.  They could fix your problem.
I have used the Advise VIs in the latest version of FieldPoint and they seem to work fine.  Let us know what happens.
I hope this helps.
Steven T.
(2,445 Views)
