Feedback on Front Panel Design
Hey Guys,
I have developed a front panel for the purpose of viewing previously recorded data. Could you provide some feedback on the front panel design, both the good and bad.
Thanks.
Message 1 of 14
(1,380 Views)
Hi bilalskd,
Some points:
  • I prefer right-aligned numeric data, with the same number of fractional digits (if applicable). I would check the table and the graph scales…
  • Labels should follow the same formatting: some are centered, some are left aligned with the control, some are "free"…
  • Table: There's a typo in the table header…
  • Table header: Frequency comes with unit Hz, magnitude doesn't have a unit?
  • Table: do you really measure frequencies accurately with 9 decimal digits? (Don't show more digits than you can measure. 16bit ADs only provide ~5 decimal digits…)
  • The button "EI Guidelines" should have the same height as the "Stress Level" indicator. The button description should be centered. (visual appearance)
  • "number of averages" is cut off on the right…
  • More strict spelling: either have all labels start with capital letters or none, but not mixed…
  • Is the frontpanel set to scale with size? There's a scrollbar at the right to indicate even more graphs!?
  • Graphs: the FFT graph shows units at the scales, the Time graph doesn't…
  • Graphs: do you need the word "Waveform" in the Time graph label? Isn't the FFT graph showing the "FFT Waveform"?
  • Why is "Datalog settings" colored while the other labels aren't? ("Datalog" is a special LabVIEW term: do you use them or do you create "more usual" data files?)
I like the graph look… 😄
Message 2 of 14
(1,370 Views)
Why do you have mMPa as unit? MilliMegaPascal, Wouldn't it be easier to use kPa, or even hPa (as often used in atmospheric measurements)?
Qestit Systems
Certified-LabVIEW-Developer
Message 3 of 14
(1,360 Views)
Unfortunately that is a requirement to display the unit in MPa.
Message 4 of 14
(1,344 Views)
Fair enough. 🙂 As mentioned, adjust right and set the same decimals shown for easier reading.
Qestit Systems
Message 5 of 14
(1,326 Views)
Thank You GerdW for the feedback.
Yes I need the word 'waveform' in the time graph. I don't need to mention 'waveform' in the 'FFT' graph as it is a spectrum and this is the standard nomenclature for these graphs for my application.
Regards.
Message 6 of 14
(1,323 Views)
If the data is streaming, or large, a STFT might be more insightful than a FFT.
Message 7 of 14
(1,291 Views)
@GerdW wrote:
Hi bilalskd,
Some points:
What do you think about the overall impression?  That's probably more what the OP was asking.  Things like "is it well organized?" stuff like that.
Bill
CLD
(Mid-Level minion.)
Message 8 of 14
(1,277 Views)
Hi Billko,
the overall impression is "quite ok" - but I'm finicky about UI/UX.
More comments after looking at the latest image:
  • use only a limited number of fonts/font settings. Right now there are several font sizes, regular/bold, colors…
  • the background on the left side seems to be mis-aligned with those light-gray boxes, white borders… (visible around the "averaging parameters" cluster)
Message 9 of 14
(1,266 Views)
@GerdW wrote:
Hi Billko,
Just want to make sure that you know I wasn't criticizing you or disagreeing and I figured you probably felt generally it was okay because you just skipped right over it.  I was just quite curious about the overall impression you got.  🙂
Bill
CLD
(Mid-Level minion.)
Message 10 of 14
(1,236 Views)
