Feedback note - what's wrong?
I tried to write a VI such that everytime when the OK button is pressed, the numeric indicator will increment one.
But it doesn't work as expected.
I am using feedback node method.
Please help.
(3,481 Views)
Why not use an event structure instead?
Bill
CLD
(Mid-Level minion.)
(3,480 Views)
Event structure cannot be used in my context.
(3,472 Views)
So, you're saying you are being forced to do it this way?  Like, as an example, for an assignment?
Bill
CLD
(Mid-Level minion.)
(3,466 Views)
Accepted by splee
it seems you are using "continuous run" mode, which reinitializes yor feedbanck node wkth every auto-restart. place a while loop with a delay around your code and use the regular run button.
(3,464 Views)
It get reinitialize every time you press ok so you will always get the same value at the output.
Ben64
too late, Altenbach already responded!
(3,461 Views)
