Faulty Analog Output
Can anyone please take a look at my VI and see whats wrong with it?? I'm unable to produce any analog output signal for my DAQ card under DAC0OUT. Could it be my settings instead? Help me!!! My brain is exploding! 😞
(2,551 Views)
Hi June,
The VI you are using to write the output should have the iteraction wired.
This value tells the VI that it should init the device when the values is zero.
All other calls will re-use the previously configured channel.
On another note;
You could be setting yourself up for trouble by saving to the LV supplied .LLB's.
Ben
(2,551 Views)
