Fatal Internal Error: "drawmgr.cpp" line 3793
Well if anyone is still interested it appears that the issue was NOT fixed in SP1
program died at 64 hrs with the same old drawmgr.cpp error
been beating on this for a year and as you can guess upper management is getting a bit restless
hope someone decides to fix this soon.
Message 21 of 30
(5,270 Views)
I have had this exact error too in a compiled executable.  The executable was compiled in 32 bit LabVIEW 2010 and was running on 64 bit Windows 7 enterprise edition.  We have not seen this error in LabVIEW 2011, but unfortunately there were other errors with version 2011.  Specifically, Memory Access Violations using LabVIEW 2011 (Access violation (0xC0000005)).  These issues are killing us.
If anyone from National Instruments is listening, PLEASE work on solving all these critical bugs in LabVIEW.  Instead of coming out with a new version every year, it would be better if you worked on creating one stable version of LabVIEW that we could count on.
Message 22 of 30
(5,185 Views)
I no longer have this issue, it has to be related to one of three things.
I was using tabs - removed them from the interface -  I have a feeling this was the cause
I was using MS Access as my db, switched to MySQL
and I can't remember what the third item I changed was and I can't find my notes 😞  it was interface realated
last test sequence was run for over 1700 hrs with no problem.
Message 23 of 30
(5,181 Views)
Thank you for updating me on how you resolved it.  We use tabs extensively so eliminating them isnt really an option.  Are you using serial communications? If so, what type of serial port hardware are you using?
Message 24 of 30
(5,177 Views)
I comminicate with a chiller over RS-232, using the PC's built in serial port, can't say I've had any issues there.
I'm getting it's temperature reading once every 20 seconds or so...
Message 25 of 30
(5,174 Views)
Hello Andy,
To make sure i understand you correctly:
Are you getting the drawmgr.cpp Fatal Internal Error as well as the Memory Access Violation?
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
Message 26 of 30
(5,150 Views)
Looks like this is probably the issue I have been having that was causing the Memory Access Violation.  Thanks to NI support for figuring it out!
1. Bug Fixes
The following items are bugs fixed for LabVIEW 2012 SP1
IDFixed Issue
356459 Crash in DrawPlot when trying to display 42984 points on XY Graph
Im not sure if this relates to the drawmgr.cpp error or not...
Message 27 of 30
(5,149 Views)
I am experiencing the same kind of problem, but while I try to build an executable.
The project file is about two years old and we've been doing builds on it a couple times every month with updates to the original application.
Recently, we were getting an error 1003 on build attempt, claiming one of the VIs was broken. Everything ran fine in Developer mode and the "broken" VI ran fine as well, no broken arrow. We did a mass compile, which didn't resolve the problem.
Finally, I took the "broken" VI and renamed it. Then I saved a copy of the renamed VI back to the original file location. The 1003 error during builds went away.
Instead, the build would progress maybe 1/6th of the way through the progress bar, then completely crash the LabVIEW developer environment.
Here's the error message we get from LabVIEW Crash Reporter:
DAbort 0x9b027400 in drawmgr.cpp.
Version: 12.0.1f4 (32-bit)
Any ideas? Attached is the error data.
Message 28 of 30
(5,107 Views)
I found out, that this error occured because there are so much UNSAVED info in your VI.
Temporary this error can be removed by decreasing autosave time as less as needed. It was set to 5 minutes - crashes almost every 15 mins, after decreasing to 2 minutes - no crashes for 3 days.
I think that crash type caused by too small memory available to storing unsaved changes of VI (ypur VI is too big and so many unsaved changes).
IMHO, but thinking so I was able to remove this error.
PS Operating and programming on Fastwell CPC304 (AMD Geode 500MHz, 256 RAM, VI size almost 500 KB w/o subVIs, WinXP + LV2009 running well!)
Message 29 of 30
(5,085 Views)
I was running into the same error message "DAbort 0x9B027400 in drawmgr.cpp" on my machine with LabVIEW 13.0.1f2 on Windows 7 Professional 64-bit
The compile would run about 1/3 of the way through and then labview would stop and show the crash reporter. In my case it turned out to be the "GDI Object" problem described in the 3 posts linked below.
http://digital.ni.com/public.nsf/allkb/ED23C965B6F2BDA586257AB5007880F7
http://forums.ni.com/t5/LabVIEW/Application-Builder-Crash-drawmgr-cpp-line-3570-when-building/td-p/6...
https://forums.ni.com/t5/LabVIEW/Silent-crash-when-building/td-p/1233575
I confirmed this by using windows task manager during the compile to observe the numnber of GDI objects.
Instructions on displaying GDI objects in windows task manager are here
http://technet.microsoft.com/en-us/library/cc958260.aspx
Within about one second of reaching 10000 GDI objects, the LabVIEW crash would occur.
I tried changing the registry as described in the 2nd linked post to 20000, restarted the computer and still the compile would crash at 10000 GDI objects.
Instructions can also be found here
http://msdn.microsoft.com/en-us/library/ms724291.aspx
I checked the registry again and found the that value in the key had reverted to 10000. I changed it to a smaller number (15000 this time) and restarted the computer. The compile needed about 10100 GDI objects in my case and LabVIEW would run without crashing.
Message 30 of 30
(4,959 Views)
