Failure : "resource.cpp", line 2477
When building an application on LABVIEW 6.1 on Window 98, I get the error message:"Failure : "resource.cpp", line 2477". Attached is my Labview failure log file
(3,793 Views)
Hi Kluu,
This error appears when checking the "Do not compress target file" option when building an application. The workaround is to not check that option in Application Builder.
While in the application builder, in the "Target" tab, in "Build Options", do NOT check the "Do not Compress Target File" option.
We are currently looking into this and will soon be fixing it up.
Hope this helps.
Pravin Borade
Applications Engineer, National Instruments
(3,793 Views)
Hi Pravin,
Thank you for your help. It's working now.
KLuu
(3,793 Views)
Ok, it is an old thread, but the problem is
still the same, I want to compile for an old
NT4.0 computer in the lab, so I want to compile
with 6.0.2.
Is there a fix available? I have not found
a patch.
Stefan
(3,533 Views)
Stefan,
It looks like this was fixed in LabVIEW 7.0.  There is no patch for 6.0.2, so you will either need to upgrade or use the workaround offered in Pravin's post above.
(3,520 Views)
Hi Devin,
the exe-file is for an NT4.0 Computer with old
(but still good) NI-Hardware.
But thanks for this information.
Stefan
(3,517 Views)
