SignalExpress and the others crash instantly in Vista
Trying to start any NI software, all I get is an immediate crash. Vista Home Premium 32-bit.
Test Panels, SignalExpress, SignalExpress for DAQ.. same result.
A quick test indicates that it seems to work fine under XP.
(2,808 Views)
Hi Lars,
it is hard to tell if your products are compatible with Vista or not since it is version dependent. Here is a link that shows which products and versions that are Vista compatible.
Kind Regards
Andreas
Andreas E
(2,789 Views)
Hi, I have the USB-6008 and the latest software/driver.
Test panels, SignalExpress etc are the latest versions. I've given up on this, I will develop under XP instead. Vista is such a pain, I only run it at home as a test and thought I could play with the 6008 there, but I guess I'll use one of my work PCs (with XP) instead.
(2,781 Views)
