Failed in updating ActiveX parameter definition
In Labview 2011. Our Labiew calls another program through ActiveX. When some ActiveX interfaces' paramether definition is updated ( such as from U8 to I32). The labview will not automatically update the active invoke nodes. The calling will result in error ( the I32 will be converted to U8 before calling).  If we delete the Active invoke node and place a new one, the interface will be updated. It is very difficult for us to update all the nodes in this way. Does any one have the same problem and have any solution?
J.K.
(2,476 Views)
The problem is only checked in LV2011. Does other version has the some problem?
J.K.
(2,469 Views)
