‎04-21-2026 05:52 AM
I am using the 2026 Q1 trail version of Labview and while i am trying to capture the image in NI-IMAQdx driver we are able to select the laptop camera but while trying to start the simulation in front panel we are getting this error.
So can anybody help us to resolve the issue.
‎04-21-2026 08:07 PM
You are asking us to help explain why some LabVIEW code that you've written, but not shown to us, generated a particular Error Message (which you did show us) at some (unknown) part of the "hidden LabVIEW code".
Here's a suggestion -- provide the LabVIEW code that causes the error.
However, here's another problem you might not realize (being a New Member) -- you are running the latest version of LabVIEW (2026 Q1), and we can't open (and view) your code unless we also have this latest version installed or you provide a "picture" of the code (and make sure we can "see" all the "wires" and sub-VIs that you might include). Do you know how to do that?
Generally, we really like to look at LabVIEW code rather than pictures of code. However, those of us running earlier versions of LabVIEW will be unable to open (and view, and test) your code. Do you know any experienced LabVIEW users to look at your code?
‎04-21-2026 11:39 PM
Hello Bob_schor, i am using the prebuilt VI which is already available in the Labview i havent created my own VI to capture the image processing.
Note: while configuring the VI i can able to select the Laptop camera and capture the video but while running in the front panel to see the output i am getting the error
‎04-22-2026 04:15 PM
Hi Pavan,
That large pale blue block is what's known as an "Express VI". If you double-click it, it opens up a configuration window. Likely there's something in there that you need to set up which isn't set up properly. Double click that and take a screenshot of its configuration, then post that here.
