FSK Modulation/Demodulation
Message 11 of 19
(3,636 Views)
I tried to do this same exact VI, but using myDAQ as sound input and using my speakers to output. But after about 10 seconds running it says: "Attempted to read samples that are no longer available." I am assuming that this is because the VI is not processing fast enough?
I am trying to use this with human voice so the rate is at 20kHz and sample to read is at 20kHz too. So it updates every second.
Message 12 of 19
(3,630 Views)
Hi, can anyone help me?!
Message 13 of 19
(3,593 Views)
Oh Sorry. I have forgot this thread  (Lot of Work to do)
That error means your data readings are not fast enough. The Main Reason is unpredictable without seeing the actual code
Try Increase the Data Samples to Read.
Can u attach your VI?
Message 14 of 19
(3,586 Views)
Yeah, I attached my VI.
I actually just created the same VI that you had but I used myDAQ as an audio input and my computer speakers as output.
Message 15 of 19
(3,580 Views)
Any solutions?
Please help me.
Message 16 of 19
(3,549 Views)
Hi Gear,
After looking at your VI for a bit, it seems that what is happening is that there's too much happening inside the while loop so data is being overwritten before it can be read.
Here is a KB that deals with the particular error code you are receiving and it also goes over some ways to resolve it.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019KTeSAM&l=en-US
Gabriel M.
Product Marketing Engineer - Academic Courseware
Message 17 of 19
(3,528 Views)
So, to fix this problem should I write to a file and read from the file? So it doesn't overwrite? Is that I proper way to fix this problem?
This is the only way that I think I can fix this after reading this KB that you sent me.
Message 18 of 19
(3,523 Views)
You could do a write to a file and then read from a file. Or you could implement a producer/consumer loop. The producer loop would acquire your data and put them into a queue while the consumer loop would play back your file.
This paper will describe this architecture in more detail:
https://www.ni.com/en/support/documentation/supplemental/21/producer-consumer-architecture-in-labvie...
Also you could go to File > New.. > From Template > Frameworks > Design patterns > Producer/Consumer Design Pattern (Data) for a VI template that you can work with.
Hopefully these help!
Gabriel M.
Message 19 of 19
(3,512 Views)
