FPGA
Hello to everyone.
I would like to know does the Tick Count Express VI give output in real time when used in Target VI? Does it count in ms in real time or in computer time?
Thanks in advance.
(5,133 Views)
Neither. As the name says, it's a tick count. The count increments at a known rate starting at 0 and going until the counter rolls over -- at which point it goes back to 0 and starts over.
For a 32 bit counter and a 1msec tick rate, the counter will roll over about every 42 days of continuous operation.
Mike..
Certified LabVIEW Architect
LabVIEW Champion
(5,111 Views)
Mike,
thanks for your help.
Yes, count increments at a known rate. But if the rate is 1ms, does it increment every 1ms in real time?
I am asking this question because I work with simulated I/O now, but in near future I will use my VIs on real system.
Thanks in advance.
(5,098 Views)
On a PC, nothing is in real time (i.e. deterministic). Now having said that, a 1msec rate is pretty slow in computer terms, so it tends to be "real-er" -- you see fewer effects of Windows latency.
How accurate does this tick need to be?
Mike...
LabVIEW Champion
(5,079 Views)
Well, it has to be exactly 1ms. Okay, I can't expect counting in real time on a PC, but when I compile Target VI on RIO device can I expect real-time counting?
Thanks in advance.
(5,070 Views)
Accepted by Chupka993
Yes.
Mike...
LabVIEW Champion
(5,062 Views)
