FPGA xillinx XC3S-100E support. Downloading problem
installed programs:
Labview 8.6 professional dev. system
Labview FPGA module for 8.6
Xillinx spartan-3e Labview Driver.
Operation System:
MS windows xp prof. with SP2.
Hardware:
Basys Xillinx Spartan3E- xc3s-100E   FPGA kit (The hardware has a JTAG progamming port. But, parallel port (LPT) cable included).
The Problems :
I constituted a new project according to the document (Getting Started With LabVIEW FPGA ). I didn't have a problem in this step until, I clicked the Run button of the Labview working page.
When I clicked  the run button, Generating Intermedia file window was appeared.it was passed successfully.And then compiling VI for FPGA window was appeared. And, Labview FPGA complile server 8.6.0 was appeared.After a while the Compile was Completed.Later, When I clicked the Run button again, an error window was appeared in Labview  (error code 305001) I attached the view of the error window.
Can not  I download in the my hardware because of, I have the kit which parallel port ? How will I do it ?
Does The LabVIEW support this KIT ?
Thank you
best regards.
Ercan Cosgun
(3,312 Views)
Hi 1245,
After looking at this and your other forum post, I believe the problem might lay with the LabView fpga module communicating with Xilinx spartan-3e driver, have you tried reinstalling the driver?
this could solve your problem.
John McLaughlin
Academic Account Manager
National Instruments UK & Ireland
(3,299 Views)
Hi
Thank you.
I tried. But, I was not succed.I don't know where the problem  is. Did i install true software ? I wrote above. if you look The figures which I attaced, I am happy.
Best regards.
Ercan COSGUN
(3,284 Views)
