[FPGA] xilinx ise?
I'm trying to configure a xilinx coregen component and LabVIEW won't let me because 'xilinx ise is not installed with labview fpga'. I can't find a suitable download from NI. Is this an expected issue? There is of course the xilinx website, but do I need a specific version, and how do I tell? Target FPGA is Virtex-6 LX195T if that is a factor. LabVIEW 2013.
Message 1 of 8
(4,314 Views)
Accepted by ToeCutter
Hey ToeCutter,
Do you have the LabVIEW 2013 FPGA Module Xilinx Tools installed locally? That includes Xilinx's coregen component, which is what you'll need to configure their IP. If you're dropping some of the IP from the LabVIEW FPGA palette, it should 'just work'.
Cheers!
TJ G
Message 2 of 8
(4,269 Views)
As T-REX mentioned you will need to have the Xilinx toolchain installed locally for the Xilinx coregen IP to work
You can find the link to the Xilinx tools 14.4 here:
https://www.ni.com/en/support/downloads/software-products/download.labview-fpga-compilation-tool.htm...
Thanks and Regards,
Thanks and Regards,
Supreeth.K
Message 3 of 8
(4,241 Views)
Thanks a lot gentlemen, that was the problem.
I had the 10.(something) tools installed but not the 14.4. Why couldn't the error message just say 'you need xilinx tool 14.4'? 🙂
Cheers
ToeCutter
Message 4 of 8
(4,233 Views)
Forgot to circle back on this: I filed a bug report on the poor error message. If you want to check on it's status in future versions of LabVIEW, contact our support team and mention CAR #458043.
Cheers!
TJ G
Message 5 of 8
(4,174 Views)
Thanks, T-REX! Was going to do it myself but I couldn't see where to raise a bug report?
Message 6 of 8
(4,154 Views)
Well, the only real way to report a bug (for customers) is through our support team in Applications Engineering. Since I work at NI, I just filed one to the correct R&D team.
Cheers!
TJ G
Message 7 of 8
(4,123 Views)
Thanks for the info, T.
Message 8 of 8
(4,120 Views)
