FPGA: why does my loop run so slow?
I have a loop executing on my FPGA (7854R card) that is running much slower than I would expect. Looking at the code, I would expect the limiting factor to be an analog output; that block takes around 42-43 ticks to execute on its own, and I have pipelined the loop to isolate that block. I have taken the loop apart and benchmarked many of the separate parts, finding that all of the other parts take much less than 40 ticks to execute. But when I put all of the parts together, the loop takes around 133 ticks to execute. Can you help me figure out what might be causing this slowdown?
I have attached the .vi in question. You may notice that it is incomplete, since I have eliminated the rest of the function of my program to make it as simple to understand as possible.
(3,919 Views)
You can have lot of your logic and math inside a SCTL http://zone.ni.com/reference/en-XX/help/371599H-01/lvfpgaconcepts/using_sctl_optimize_fpga/
That should help.
There are other optimisation techniques as well, these links may be useful if you havent seen them already:
http://www.ni.com/white-paper/3749/en
http://digital.ni.com/public.nsf/allkb/311C18E2D635FA338625714700664816?OpenDocument
http://digital.ni.com/public.nsf/allkb/722A9451AE4E23A586257212007DC5FD
CLA CTAChampionI'm attending the GLA Summit!
Subscribe to the Test Automation user group: UK Test Automation Group
(3,892 Views)
Thanks, I am trying the SCTLs right now. I am also taking a look at the links you sent. Will let you know if that helps.
Here's the part that I don't get: I don't see why that logic should take more than the 40-ish ticks required by the analog output block, much less the 133 clock ticks it currently takes. If I break the code down into smaller chunks, they all seem to run at reasonable speed. It seems that it's only when I put them all together that the slowdown happens. Any insight into that behavior would be appreciated too.
Thanks again for the assistance.
(3,858 Views)
I read through all of your links... I had already read the first two, but I picked up a new piece of information somewhere along the way.... A SCTL not only makes code run faster, it also saves FPGA fabric. I didn't realize that.
My issue seems to be the divide function. It takes 60+ cycles to execute. I had two of them cascaded, resulting in 133 cycles for the whole loop. I could swear I had benchmarked the divide function separately, but when I benchmarked it today it came out at 60+ cycles. The high speed divide function is about twice the speed; I've switched to that function.
I have pipelined the two divide functions (that will require some adaptation of adjacent code, but that's OK). I'm also playing with how much of the other logic I can put in one SCTL; I know I can break it into two SCTLs and it will compile.
My loop is currently running at 44 cycles/iteration, so there's not much room for optimization in speed. I will make a few more attempts with SCTLs to save some fabric, but I'm just about where I wanted to be.
Thanks for the help!
(3,854 Views)
If you want to save fabric the SCTL is definitely a good choice. In addition you can also save some by:
- checking the FXP number representations (for the divisions this will also save ticks). E.g. the 40020000 constant does not need to be 30 or even 50 bits wide.
- avoid divisions when possible. One of your divisions divides by a constant. You can easily change that into a multiplication. Also, you can specify the output type of a FXP calculation.
Also, pipelining makes sense, but if you do so, try splitting your critical path (the 2 divisions) as well. For instance the second division could probably be in parallel to the first one (also when switching to multiplication this might make sense).
(3,835 Views)
A quick way to reduce the types of constants is to right-click on the constant and select "Adapt to Entered Data". This will give you the optimal fixed-point range that fits the number automatically. The reduced ranges will automatically propagate through the diagram, reducing bits needed for downstream operations as well.
(3,783 Views)
