FPGA time
I am using FPGA. I have while loop and inside the while loop I have case-structure with three cases. Everytime I choose some case I want the real time starting from 0. I need this time in case. Any idea how I can do it?
BR
Message 1 of 10
(5,067 Views)
Hi WatFin,
Please explain "realtime"…
How is this problem related to FPGA?
3 simple steps:
1. Store the "time" in a shift register.
2. Wire through your case structure.
3. Set the value to zero when you think it is needed to do so…
Message 2 of 10
(5,064 Views)
What exactly do you mean by the "real time"?
You can set a separate timed while loop based off the 40 MHz clock and increments an indicator by 1 every iteration.  Read the indicator with a local variable and you'll have how many clock ticks have passed.
Message 3 of 10
(5,063 Views)
Ok, what is real time? I hvae crio with 40 MHz and my loop sould work 2,48 kHz. The real-time I meant is the time we use to look at.
Could you show me basic example please?
Message 4 of 10
(5,052 Views)
Hi WatFin,
put a (RealTime) wait in your loop set to 16129 ticks (of your default 40MHz clock) to have it iterate at ~2.48kHz…
What are you "looking at"? ("Real-time")
Message 5 of 10
(5,044 Views)
@WatFin wrote:
real time
Just to clarify this thread: You so-to-say want to program a stop-watch that starts counting from 00:00:00 again every time you "press" the reset case. Is this the "real time" you mean?
Ingo – LabVIEW 2013, 2014, 2015, 2016, 2017, 2018, NXG 2.0, 2.1, 3.0
CLADMSD
Message 6 of 10
(4,995 Views)
Yep that I want to do. The real-time is the clock time 0 1 2 3.. etc
Message 7 of 10
(4,985 Views)
Hi WatFin,
you still can count clock cycles/ticks/iterations of your loop in the FPGA: just scale that number later on to your desired timebase of seconds (or ms)…
Message 8 of 10
(4,980 Views)
I am communicating with FPGA and RT. Code for Pulse generation (for 100KHz freq i.e. 10usec - 400 ticks)  is written in FPGA. But in RT using this FPGA code I'm not getting the same frequency. I am getting only 70 ticks instead of 400 ticks. Help me in solving this..
Thank You
Message 9 of 10
(3,564 Views)
Thank You
Message 10 of 10
(3,562 Views)
