FPGA on cRIO
Hi
I have a NI cRIO 9066 with 9401 modules which I am using to try and control a Pololu 100:1 Metal Gearmotor 37Dx57L mm with 64 CPR Encoder. I am trying to use the encoder outputs to calculate the angle/position. I have seen examples of angular encoders on DAQ devices. I am trying to find one to use it on FPGA. Are there any such options? I have attached a picture of a DAQ example I looked at. I also looked at other forum posts on this topic but they were not very helpful or I couldn't use the advice.
Sid
(3,235 Views)
Hi sidpen,
AFAIK there are example VIs showing how to create encoder counters using simple DI pins with an FPGA.
You just need to check for rising/falling edges on your DI signals and use them to count the encoder pulses!
(3,230 Views)
Hi GerdW
I did try to do just that and I have attached an image of the VI I used but I am getting wrong results. The image shows my two encoder inputs (DIO1 and 2) that I am counting to get total encoder pulses per revolution. But I am getting far more than the 6400 pulses I should be getting per revolution.
(3,227 Views)
Hi sidpen,
Have you seen this document, specifically #3 where it mentions configuring your encoder application on a cRIO?
It also mentions using DAQmx tasks, but this will not be possible with your cRIO 9066. That is a new feature offered with our 904x chassis, such as the cRIO 9045.
Let me know how that works for you!
Timothy D.
Applications Engineering
(3,190 Views)
