Error Case - What other cases accept?
The Case Error Structure allows we to add cases, What are the allowed cases? What is the syntax?
(3,959 Views)
From your question what i understood is if you connect Error cluster to the case selector you will get 2 cases i.e error and no error.
I think you cannot add other cases if you wire error cluster to case selector.
Expand.Evolve.Influence
(3,949 Views)
Hi Carlos,
Did you read the LabVIEW help for the case structure?
(3,936 Views)
If you wire an error wire directly to a case structure, the only available cases are "Error" and "No Error".  The case structure is examining the status element in the error cluster, which is a Boolean value which you can unbundle. The "Error" case corresponds to a TRUE status element, and "No Error" to a FALSE status element. If you instead unbundle the error code from the error wire and wire only the code into the case structure, then all valid integers for that datatype are available (-2,147,483,648 to 2,147,483,647) as cases for you to implement custom error handling functionality.  Not all of these codes will be used by LabVIEW, of course. You can define custom error codes in the range of –8999 through –8000, 5000 through 9999, or 500,000 through 599,999.
(3,913 Views)
Accepted by topic author dgd.gomez
I think the question is related to the fact that when you right click on the case structure you have an "Add Case" option.  It exists on Error/No Error case structures and also True/False case structures.  Note that both of those are strictly binary case structures.  They only have 2 choices, either/or.  You can add a 3rd case, but as soon as you do, you'll generate an error either because the new case is undefined, or if you edit it to be True or False, or Error or No Error, you'll still have a broken run arrow because now that case structure as duplicate cases.
(3,898 Views)
Really, this was the question. For some reason the image isn't loaded and confusion may have been generated.
The question was motivated by some pages that I found on the internet
Warning case in Error/No error case structure
Error-code-case-selector
Allow-Error-Case-Structure-to-Handle-Specific-Error-Numbers
Try-catch-structure
Warning-case-in-Error-No-error-case-structure
...and when I saw the option of a new case, it made me doubt.
(3,882 Views)
