Showing results forĀ
Search instead forĀ
Did you mean:Ā
FPGA compiling error 424
Here is an FPGA project with 7833-FPGAs, which after the configuration step leads to compilation error 424.
The same project with 7842 is successfully compiled.
This problem solution from NI unfortunately does not work with 400MB, 500MB or 4GB....
http://digital.ni.com/public.nsf/allkb/93142B590BB3B60786257893006F4AE3
LabVIEW 2010SP1 and Labview FPGA modules are used in evaluation mode in a Virtual Machine with Windows XP 32bit on a Windows 7 64bit PC.
Error-Log:
### CoreGenerator ###
WARNING:sim:89 - A core named
   <ipram_lut_sine_wave_generator_nifpgaag_ni_munge_4gs_afe_fpga_vi_fpgacompilec
   opy00000001_vi_colon_2> already exists in the output directory. Output
   products for this core may be overwritten.
ERROR:coreutil - Exception caught when running XST synthesis!
ERROR:coreutil - Failure to generate output products
ERROR:coreutil:424 - An error occurred while running Java. Please examine the
   console or coregen log file for a specific IP related error.
    For more information please search the Xilinx Answers Database for this
   error: http://www.xilinx.com/supportERROR:sim:57 - Error found during generation
(3,597 Views)
Hi Rokot,
please take a look at this:
http://digital.ni.com/public.nsf/allkb/93142B590BB3B60786257893006F4AE3?OpenDocument
(3,531 Views)
Hi Wolfgang. That is the same solution suggestion which is in the first question. I does not help.
(3,524 Views)
