FPGA compilation stops at "Synthesizing: Report RTL Partitions:" with 0% CPU cost
Hello:
I meet a problem when compiling my FPGA code:
It stops at Synthesizing, and the xilinx log stops update at :
| |RTL Partition |Replication |Instances |
In task manager I can see the vivado is not doing anything right now.
I'm working with FlexRIO 7935, LabVIEW 2018 f2
In my code i'm using DRAM with some BRAM (about 25%), and some host to target/target to host FIFO, as well as some DSP48, code write in two clock domain, DRAM clock and 40M Clock.
If I put all code in DRAM clock domain, it actually compiles, but with DSP48 fail to meet the timing requirement,  so I use a FIFO to separate DRAM operate and process code, and it here I meet this problem.
I already checked my system is working, I can compile blank VI, as well as some other simple VI.
Any advice? Thanks!
(4,046 Views)
Accepted by topic author jiangliang
OK,I get the problem.
I should not put Input or output terminal in DRAM Clock domain.
I'm now using register as a buffer, things works.
Nonetheless it is a bug NI should look into, I think many might be confused when face such problem, the error simple didn't provide  any information on it, and LabVIEW doesn't have any mention about Input/Output should not put in DRAM Clock Domain.
(4,019 Views)
One more thing.
You should not put a Host to target FIFO status node in DRAM Clock Domain SCTL, you can not finish compile the code, also, you won't know any detail about why it fails.
(4,008 Views)
