FPGA communication error: Error -123002
I know there has been many of these, but none of them seemed to apply. I'm entirely new to FPGA, took over for someone else on this so any help would be great.
I'm trying to use the local compile server, and I'm fairly certain we have Xilinx installed (not sure where it is though).
I get this error:
Project: NEERhi - Phase 2.lvproj
Target: FPGA Target (RIO0, NI 9146)
Build Specification: FPGA
Top level VI: FPGA.vi
Compiling on local compile server
Compilation Tool: Xilinx 12.4
Start Time: 8/23/2017 11:45:53 AM
Run when loaded to Fpga: FALSE
Xilinx Options
Design Strategy: Balanced
Synthesis Optimization Goal: Speed
Synthesis Optimization Effort: Normal
Map Overall Effort Level: High
Place and Route Overall Effort Level: Standard
JobId:
Working Directory: C:\NIFPGA\compilation\NEERhi-Phase2_FPGATarget_FPGA_4559771E
In details, I'm told:
Error -123002 occurred at niFpgaCompileFarm_OpenJob.vi
Possible reason(s):
NI-Farm: No worker has registered the given capability name.
Complete call chain:
niFpgaCompileWorker_OpenJob.vi
niFpgaCompile_Worker.vi:1
Message 1 of 9
(6,417 Views)
According to https://www.ni.com/en/support/documentation/compatibility/19/compatibility-between-xilinx-compilatio... you need to install ISE 11.5.
Are you running LabVIEW 2010 SP1 or 2010 wo/SP1?
ALE Consultants
Message 2 of 9
(6,403 Views)
Nope, definitely using LabVIEW 2011. We've compiled the FPGA before, but I had to make a modification to the code. I ran the compiler, and at first it didn't communicate. Then it started to run, and half-way through it threw a communication error.
Unfortunately, I can't reproduce that sequence of events. It just simply won't communicate now.
Message 3 of 9
(6,393 Views)
Was the compile on the same PC?  Has anything changed?
ALE Consultants
Message 4 of 9
(6,389 Views)
Accepted by sjacksonPA
I got the compiler to communicate. The CompileWorker isn't shutting down properly so I have to close it through the task manager.
Now it's throwing this error:
Error -61319 occurred at niFpgaCompileFarm_GetJobStatus.vi
Possible reason(s):
LabVIEW FPGA: The compile farm server aborted the compilation.
LabVIEW FPGA: The compilation was aborted by the compile farm server.
niFpgaCompileWorker_GetStatus.vi
There is only one thread I could find on it. One suggestion was it's a firewall, but no consistent resolution to the issue was found.
Message 5 of 9
(6,384 Views)
Can you compile locally?  Then there should be no firewall issue.
ALE Consultants
Message 6 of 9
(6,372 Views)
That's actually how I've been compiling. And my .net is 4.0 which I think is fine for 2011.
Message 7 of 9
(6,368 Views)
I am getting communication error. error -123002. How do I resolve it?
Message 8 of 9
(5,751 Views)
I had the problem - and this fixed it.
(Ctrl-Alt-Delete, Task Manager, then manually end the task)
Message 9 of 9
(4,214 Views)
