FPGA case structure
hi,
  i'm developping a simple LV FPGA program on a compact rio using the 9401 module.
  i'm tryning to controle sequencely the DIO of the module by a flat sequence (sequence -> delay-> sequence->delay) , (see picture attached), i'm not sure it will work,
  what i your opinion on this side?
SASA
Message 1 of 13
(4,623 Views)
Hi SASA,
use a flat sequence instead of a stacked one. Until now we cannot see, what's happening in those other 2 frames…
- You only open the FPGA VI ref once, so closing it twice seems not right to me…
- As your while loop never stops you will never close your FPGA VI ref…
Hint: Did you notice this little "Auto Cleanup" button in the menu? Guess what it's for…
Message 2 of 13
(4,619 Views)
You have to configure the DIO direction (Input/Output) first before accessing the IOs. By default your DIOs will be in the Input mode and you have to Enable the Output before accessing it as DO.
Message 3 of 13
(4,606 Views)
Hi GerdW,
  😉 i always used "auto cleanup" button,
  at the begining  i tried the solution you described, but stacked sequence seems to me less consuming in the vi space 🙂
 but i will re-use it,
 olz see the picture attached,
SASA
Hi SASA, use a flat sequence instead of a stacked one. Until now we cannot see, what's happening in those other 2 frames… - You only open the FPGA VI ref once, so closing it twice seems not right to me… - As your while loop never stops you will never close your FPGA VI ref… Hint: Did you notice this little "Auto Cleanup" button in the menu? Guess what it's for… Best regards, GerdW CLAD, using 2009SP1 + LV2011SP1 (sometimes even LV2014) on WinXP+Win7+cRIO Kudos are welcome Smiley Wink
Message 4 of 13
(4,605 Views)
Hi SASA,
between execution of the last and the first frame (when the loop spins) there is no delay. So right after setting/reading DIOs they will be read/set again.
I don't think that's what you want…
Message 5 of 13
(4,571 Views)
Hi GerdW,
   didi you have seen the waiting "ben" of 200 ms, it's a waiting time, didi you think the opposit?
SASA
Message 6 of 13
(4,555 Views)
Hi SASA,
yes I have seen the wait instruction between frame 0 and frame 2. But what's the wait time between frame 2 and frame 0?
When frame 2 is finished the loop iterates and frame 0 is executed instantly - resetting all DIOs so you will NOT notice any changes on the output pins…
Message 7 of 13
(4,552 Views)
HI GerdW,
  so what solution you have in mind (delate the while loop)?
SASA
Message 8 of 13
(4,549 Views)
Hi SASA,
you need a wait function after frame 2…
Message 9 of 13
(4,546 Views)
Hi GerdW,
   I will come to you after testing the code.
  Thank you very much.
 SASA
Message 10 of 13
(4,539 Views)
