FPGA cannot install
Hi, we have Labview Fall 2012, iso's Labview 1-4 plus Additional xilinux compilation tools iso. We have installed labview OK and then tried installing module FPGA but it cannot find module on any of the iso's. Can you advise please. Thanks.
(2,715 Views)
Accepted by nlew002
Did you select to install LabVIEW FPGA from the installation menu on Disc 1?  You mentioned that you are using .iso files, meaning you are not using the physical CDs?  You might want make sure the iso is mounted properly in whatever software you are using (MagicISO etc.).  Also could be the iso is corrupted.
(2,687 Views)
Thanks JKMM for your response. Yes it is looking like some sort of file corruption after we unpacked the disk 2 iso to a local folder. I have tested the FPGA install on another machine OK from the same iso's so original iso's OK. Thanks again for your time and help. I have closed the call with your response as the solution. Cheers.
(2,669 Views)
