FPGA: are typedef coercion dots bad for efficiency?
Howdy--
Using LV 2011 FPGA, I always get coercion dots when reading or writing to/from FIFO or Memory items typed with a typedef.ctl.  Do these indicate some extra use of resources in the compiled code, or are they harmless?
Thanks a bunch all, and have a great day.
--Brad
(2,965 Views)
Accepted by topic author BradNC
As long as being a typedef or not is the only difference it shouldn't matter.  The dot comes from a regular element pretending to be a typedef.  You're not changing type so new memory won't be allocated.
I32 typedef uses same memory as standard I32.  If you push an I16 typedef into an I32 or vice-versa you may get a copy.  For scalars this is pretty minor, even in FPGA.
--Using LV8.2, 8.6, 2009, 2012--
(2,962 Views)
Awesome.  For a minute there I was afraid I'd have to abandon typedefs..a scary prospect when you're as scatter-brained as I am.
Thanks a bunch Taper for the quick reply.  Be Well.
(2,954 Views)
Too answer this question yoursefl you could use
Tools >>> Profile "Show Buffer Allocations...
To bring up a toll that will show where the buffers are being created.
Ben
(2,932 Views)
