FPGA and Host Communication
hello guys;
i have an application with the compactRIO and i'm using the labVIEW FPGA Mode , i have 3 VIs one for the FPGA , one for the Real Time and the last on MyComputer , the problem is when i launch the MycomputerVi the others VIs are not runing ; so how can i launch all the VIs only from the Host from MyComputer
and Thanx Smiley Happy
(2,363 Views)
Well, the RT VI runs on the cRIO.  You can make the RT VI load the FPGA VI.  But you will need to start up the RT VI separately from the Windows machine since it needs to be uploaded to the cRIO.
GCentral
(2,333 Views)
