FPGA VI not compiled.
Hello.
I want to activate my FPGA code in LABVIEW and the following 2 comments appear-
1. Open FPGA VI Reference: FPGA VI not compiled.
Details:
The specified FPGA VI must be compiled in order to be used from the FPGA Interface.
2. I/O Node: <iotype> item incorrectly configured
Details:
The I/O item is not configured for the current target or is configured for a resource that is unavailable. Right-click the I/O item in the Project Explorer window, choose Select Resource from the menu, and select a resource available on this target.
I tried to do what was written in the details, but it didn't work.
  What could be the problem and what could be the solution?
Many thanks in advance
Message 1 of 9
(4,225 Views)
Hi yael,
1. You need to compile the VI for your FPGA target.
2. It would help to see the FPGA VI with the corresponding LabVIEW project file. This lvproj file needed as it contains all the definitions of your (FPGA) target! Did you configure the FPGA target correctly, with all related hardware?
Message 2 of 9
(4,215 Views)
Hello and big thanks for the answerץ
How do "compile the VI for your FPGA target"?
What do you mean and what steps?
Thanks again
Message 3 of 9
(4,212 Views)
HI yael,
have you done any tutorial on FPGA for LabVIEW? It seems you should…
To compile the FPGA VI you need to take the same steps as creating an executable from your LabVIEW code for Windows: you create a BuildSpec, then you build it:
Message 4 of 9
(4,205 Views)
Hey,
I managed to install the FPGA and it looks "like" it works.
But in actuality at the rate the pictures are being taken, the FPGA does not seem to be really communicating.
I work with HOKAWO and streampix6.
Do you have any ideas what could be the problem? Or what should be entered in these programs?
Message 5 of 9
(4,114 Views)
Hey,
What could be the problem? Is there anything specifically to check?
Many thanks in advance!!
Message 6 of 9
(4,120 Views)
Hi Yael,
@yael1994 wrote:
the FPGA does not seem to be really communicating. Do you have any ideas what could be the problem?
As we don't have your software/code nor your hardware we have no ideas what the problem might be…
@yael1994 wrote:
I work with HOKAWO and streampix6. … Or what should be entered in these programs?
When you work with those tools then you need to read their manuals - or ask their support!
And PLEASE don't ask the same question in several threads in parallel!
Message 7 of 9
(4,110 Views)
But the problem seems to be in FPGA!!!!
Message 8 of 9
(4,101 Views)
Hi Yael,
I repeat from my previous message:
Message 9 of 9
(4,096 Views)
