FPGA Timed Loop - Set dt
Whenever I try to use a Timed Loop in LabVIEW FPGA, it doesn't give me the normal options to set the "dt" instance.  It works fine when I'm using timed loops on a Host VI, but not on the FPGA Target side.
This is what I see:
It shows the default clock as expected, but whenever I try to set another property, the only one available is the error:
Does anyone know how to set the "dt" timing parameter for a loop like this?  Thanks in advance! 🙂
If someone helped you out, please select their post as the solution and/or give them Kudos!
(4,156 Views)
Hi Asthma,
on the FPGA that loop has a different name: SCTL aka Single Cycle Timed Loop!
Please read the LabVIEW help for that loop structure!
(4,150 Views)
Where can the SCTL be found?  This is the only timed structure I can find anywhere on the pallette.  (If its not clear enough, I'm quite new to FPGA.  I also am in the process of transitioning to 2013 from 2009 so its a bit different 😛 )
(4,146 Views)
Hi Asthma,
the SCTL (on FPGA) looks like the TWL (on PC/Realtime), we are talking about the very same structure.
BUT: on the FPGA that loop behaves different than you are used to from PC/RT!
Read the help!
Go through FPGA basics found here (basics, paragraph 6)…
(4,141 Views)
That video was quite informative.  Perhaps I have the wrong structure in mind then.  My goal is to repeat a loop, say 10000 times at exactly 2 kHz.  What would be the best approach to make this happen on the FPGA?
(4,134 Views)
Accepted by MrHappyAsthma
Hi Asthma,
use a FOR loop with a Wait(FPGA) in it…
Basics: Whenever you need to iterate for a given number of cycles you should use a FOR loop.
Basics: When your loop needs timing put a Wait in the loop…
(4,132 Views)
Will do!  Thank you for the help and sorry for the confusion.  FPGA is quite a bit different than traditional LabVIEW on Windows.
(4,128 Views)
