FPGA Target not loading into Labview Project
I have upgraded my Labview and FPGA modules to 2022. Now when I try to open my project, it does not load the targets. The Main vi is also broken and can not find the FPGA open modules. Please refer to the following picture. I have active labview 2022 and fpga modules. But after the upgrade, I can see FPGA files in the project. The warning message suggests that there may be missing drivers or modules.
What am I missing here?
(1,872 Views)
According to NI Hardware and Software Operating System Compatibility, if you want to use both sbRIO-9606 and sbRIO-9607 in the same project, you can only use LabVIEW 2016 to 2019 with NI-compactRIO 19.6 in Win10.
(1,852 Views)
Zyong,
Thanks for your feedback, I still the the problem when there is only 1 sbRIO target in the project. I have following systems and drivers installed on my machine. Can you please see what is missing here?
Windows 11 Home (64-bit)
LabVIEW 2022 Q3 (64-bit)
LabVIEW compilation tool for Vivado 2021.1 Version 2022 Q3
LabView FPGA modules (64-bit) 2022 Q3
(1,814 Views)
