FPGA Sampling Rate Issue w/ 9205 Module
I would suggest:
- match the data type (FXP and I16). You are passing a Fixed point to a DMA set as integer. This might be why you are getting zeros.
- check if there are elements to read on the host with the property node. If # of elements to read is < # you want to read then do something else (or nothing Smiley Tongue)
- check if you are timing out the FIFO (target). Use timeout different from 0 (0 never times out, -1 waits forever). If you are timing out you are probably wrtiting too fast, reading too slow or FIFO is too small
- use shift registers to pass the error (host)
- set the sample rate (host) before you start reading the FIFO
Message 11 of 11
(410 Views)
