FPGA SGL To Integer Cast
Hi all,
Is it possible to cast a SGL to an U32 in the same way a FXP can be cast to and from integers in LabVIEW FPGA 2012?
Thanks!
-Derek Roane
(3,562 Views)
attached is a vi that will convert a fxp to sgl represented as u32
you could convert the sgl to fxp first then use this vi to achieve sgl represented as u322
- James
Using LV 2012 on Windows 7 64 bit
(3,559 Views)
Thanks for the reply.  That may work for my situation, but one problem is the FXP64.24 datatype can't handle big numbers.
I just want to be able to manipulate the sign bit of the SGL number inside a SCTL.  I'm using Xilinx CoreGEN IP nodes to process some channels in a SCTL, and I was hoping the support for SGL in FPGA 2012 would let me drop using a U32 as the input/output datatype for those nodes.
I should probably make a suggestion on the FPGA Idea Exchange.
-Derek Roane
(3,549 Views)
