Showing results forĀ
Search instead forĀ
Did you mean:Ā
Convert a picture to a bit stream
Hi
I would like to convert a picture to a bit stream . I know for example for text to bit we can use "Text to unsigned byte array" block  but I don't know how to do it with lets say a JPG (or any other format). I would greatly appreciate your help with coding or a basic example
Message 1 of 8
(5,674 Views)
If you have the jpg image as a file you can just read the file using the standard file functions (read binary file). This will return a string. If you need it as byte array you can use the function you mentioned or read the binary file that way.
Message 2 of 8
(5,672 Views)
Thanks Dan. Would you please show me how to do it in a very basic example. I tried it didn't work for me.
Message 3 of 8
(5,664 Views)
It's really simple, see snippet.
Message 4 of 8
(5,662 Views)
Great .Many thanks. Would you please also let me know how can I recover the picture from bit stream or Text to  JPG again
Message 5 of 8
(5,657 Views)
Just write the text to a binary file using the corresponding function (Write to Binary File).
Message 6 of 8
(5,655 Views)
I tried this code but it is not working
Message 7 of 8
(5,640 Views)
In the write primitve, set "prepend array or string size" to False, else it will add 4 extra bytes at the beginning of the file.
Message 8 of 8
(5,632 Views)
