キャンセル
次の結果を表示
次の代わりに検索
もしかして:
FPGA Read/write element
I'm trying to write a value to the FPGA Vi frontpanel via the host computer.
For this i use mentioned control.
I get a strange error, where a wire shows a correct connection in a not considerably different case as if it has a broken connection.
See this:
and this:
Whats happening here? Can i write only all elements at once?
Any hints? I just want to switch on the laser and let everything else untouched!
Thank you in advance!
0 件の賞賛
メッセージ1/5
4,041件の閲覧回数
Its hard to say but it looks like this could be a bug.  Can you post a VI that demonstrates this?  What version of LabVIEW are you using? What OS?
0 件の賞賛
メッセージ2/5
4,017件の閲覧回数
I would:
- Recreate the FPGA I/O node (sometimes it can bug out)
- Check that the FPGA front panel doesn't have multiple controls/indicators called 'Mode'
- Try a recompile on the windows/RT VI (ctrl + click on the run arrow)
(blog)
0 件の賞賛
メッセージ3/5
4,009件の閲覧回数
LabView 2013 with remote desktop connection, because i have only LabView 2014 on the office computer.
I can post a demo vi tomorrow, probably.
0 件の賞賛
メッセージ4/5
3,987件の閲覧回数
There are no two mode connections, because the second case is only the diminished control from the first case.
The wire connection was not touched between the making of the screenshots.
0 件の賞賛
メッセージ5/5
3,981件の閲覧回数
