11-03-2020 09:32 AM
Hope you are doing good and thank you for taking some time out for reading the post.
Scenario: I have a main loop (Producer) that generates ref sine wave. In parallel, I have two loops that captures sine/cosine (respectively) coming back from resolver which will be simply passed through analog output channel.
(Analog input [Raw format]----connects directly to------Analog output [Raw format])
I have refactored the code (attached image and VI) for simplicity to just show the slowing down part. Also, everything works as expected in simulation mode.
Problem Statement: Even by placing analog output blocks in parallel loops, the main (producer) loop slows down by:
1) One analog output block on diagram: 141 ticks (not a problem)
2) Two analog output block on diagram: 252 ticks (problem)
3) Three analog output block on diagram: 378 ticks (major problem)
(1 tick = 25 ns)
It seems like I am missing out something fundamental here. I did try out different scenarios but they all resulted the same. I would really appreciate if someone could guide me in the right direction..
-Thanking you
Additional Information: Could the update rate be affecting the loop rate?
Solved! Go to Solution.
11-03-2020 10:09 AM
11-03-2020 10:30 AM
Hi GerdW,
I really appreciate you responding.
I did put in all the AO in one loop and in one IO node as suggested. But the loop rate is still high, it is 354 ticks. I need it to be around 141 ticks.
Do you have any other recommendation? Also is increased tick count inevitable with increased AO?
Thanking you
11-03-2020 12:49 PM
What I should have written is that; I put all the AO nodes in separate loops thinking that if I processes these blocks in parallel on FPGA the loop rate will remain low for all the loops.
I get the best results when the sine wave producer loops runs at 141 ticks or less.
If there is no way to meet both the requirements, I will avoid using more than one AO node in the single code.
11-03-2020 03:50 PM - edited 11-03-2020 03:54 PM
Hi Xonmyth,
So it became faster than before by ~20 ticks!?
According to the specs the update time for 3 channels is 8.75us: 350 ticks * 25ns/tick = 8750ns =8.75us.
What else did you expect?
On "parallel access" on FPGA: on cRIO the modules are connected to FPGA using a serial bus. This bus is a shared resource! Using more channels can lead to reduced sample rates per channel.
I guess the sbRIO behaves very similar...
11-03-2020 05:22 PM
Hi GerdW,
Pardon my lack of knowledge. This is what I suspected but I was not sure of.
Thank you.
