FPGA (PXI-7852R) Arb. Wave form resolution
Hello dthrash
So you need to generate an arbitrary waveform, the frequency range is 2.5KHz to 25KHz, Do you need to change parameters on the fly?
Regards
Frank R.
Message 11 of 16
(788 Views)
No need to change on the fly
Message 12 of 16
(779 Views)
Hello dthrash
I'll be testing these examples since we need to determine the limiting factor.
Regards
Frank R.
Message 13 of 16
(761 Views)
Hello dthrash
While I am able to test this example. I would like to know if you have reviewed this example.
Regards
Frank R.
Message 14 of 16
(750 Views)
Frank,
I have reviewed that example. I have never succesfully implemented it. I liked the other example more because the wave form is saved directly to the FPGA thereby (in my mind anyway) removing any uncertainty caused by data transfer protocals.
Did you also observe the phase noise/funny business on the wave forms produced by the previous example?
Message 15 of 16
(747 Views)
Hello dthrash
no yet. I will be doing that test once I have access to my equipment. I will let you know.
Regards
Frank R.
Message 16 of 16
(740 Views)
