FPGA Host Vi Programming Slow
[ LabVIEW 7.1.1 , FPGA Module 1.1 ]
i have an very annoying effect when programming a host VI to control an existing fpga VI.
On each click, loop, read/write control, that i place on the block diagramm, the windows
Anyone an idea why ???
Ist there a solution ?
Andreas
(3,197 Views)
Hi Andreas,
Can you send me please your VIs (FPGA and Host VI)? What kind of HW do you use cRIO?
Regards
TN
(3,193 Views)
Found the solution.
I have several host VI's (Download, Task, StopFPGA....) because i build a DLL out of them later
and by splitting the tasks i get the particular function calls from the Application Builder.
And since each "Open FPGA Vi Reference" call needs about 100 ms , i open the reference only once
and put it into a LabVIEW global, using this global in the other host Vi's.
And that's the problem. Somehow LabVIEW needs several seconds for each action if i work on a host Vi
with this global as a reference to the FPGA Vi.
So to get rid of this annoying sandglass i put an "Open FPGA Vi Reference" (with selecting the target Vi)
temporarily in my host Vi's , do my coding and delete it after finishing the code.
Regards, Andreas
Message Edited by nilolo on 06-30-2005 12:33 PM
(3,190 Views)
