If you encounter access issues, please contact services@ni.com and include the learner’s name, email, service ID or EA number, and the list of required courses.
FPGA Host Vi Programming Slow
[ LabVIEW 7.1.1 , FPGA Module 1.1 ]
i have an very annoying effect when programming a host VI to control an existing fpga VI.
On each click, loop, read/write control, that i place on the block diagramm, the windows
Anyone an idea why ???
Ist there a solution ?
Andreas
(3,161 Views)
Hi Andreas,
Can you send me please your VIs (FPGA and Host VI)? What kind of HW do you use cRIO?
TN
(3,157 Views)
Found the solution.
I have several host VI's (Download, Task, StopFPGA....) because i build a DLL out of them later
and by splitting the tasks i get the particular function calls from the Application Builder.
And since each "Open FPGA Vi Reference" call needs about 100 ms , i open the reference only once
and put it into a LabVIEW global, using this global in the other host Vi's.
And that's the problem. Somehow LabVIEW needs several seconds for each action if i work on a host Vi
with this global as a reference to the FPGA Vi.
So to get rid of this annoying sandglass i put an "Open FPGA Vi Reference" (with selecting the target Vi)
temporarily in my host Vi's , do my coding and delete it after finishing the code.
Regards, Andreas
Message Edited by nilolo on 06-30-2005 12:33 PM
(3,154 Views)
