FPGA Compiler
Hi All,
Sine Generator - R Series.lvproj  is one of the examples in the Example Finder. The example is developed for PXI 7831 R Series card. But it’s mentioned that the example can run on PXI 7841 Series card also. So I created new target and devices (7841) in the PXI system and moved the Items to Move to my new target, then I run the Sine Generator (FPGA).vi but not successful. The compiler is hanging in the following window for hours.(I am using LabVIEW 2010 with xilnix 11.5 FPGA compiler)
Also I am facing the same problem when compiling the attached simple FPGA VI. This VI has only Sine Wave Generator function and I/O node.
Why I couldn't compile the attached simple VI or provided example VI. Please add your inputs/comments
Thanks in advance
Message 1 of 1
(2,669 Views)
