FPGA Compile server Queue
Are the FPGA compile servers still hung over from new Years?
I have 4 compiled queued up, went to lunch and 90 minutes after starting,t hey are still "waiting in queue"
(570 Views)
What does https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000kEZ2SAM&l=en-US show for you?
For me https://galileo.niwsc.com/ (the link from the KB) says "It works!"
On the other hand, I put a test compile into the Cloud and 10 minutes in, it is waiting.
I recommend opening a case up with NI Technical Support.
ALE Consultants
(551 Views)
Yeah, everything shows up as working, but it had to wait 2 hours in the queue before starting to compile....
Such issues with the FPGA compile servers are too common to open up a case every time. Like this one, it normally resolves itself...... But from time to time it needs input.
(518 Views)
Totally understandable on the time for submitting a case...
I sent support a message regarding this.
ALE Consultants
(502 Views)
I've done it multiple times in the past as well. I normally give it 4 hours before getting "active"
(500 Views)
Got a reply that the queue was really busy.  I guess someone's NY resolution was recompile everything 🙂
ALE Consultants
(483 Views)
