Sad about changed context menu in 2023 Q3
Dear fellow sufferers,
today I switched to 2023Q3 and first I discovered the change of the context menu when opening it on an input terminal. In former releases the first three items where "create constant", "create control" & "create indicator" and indeed these were the most used actions I had to take. They were there since LV2019 (don't know exactly) and I considered the introduction very helpful. Now we are back to the twenty tens again.
Q: some INI- switch available to turn back times?
P.S. This bug still hasn't been fixed: https://forums.ni.com/t5/LabVIEW/BUG-LabVIEW-2022-Q3-cursor-on-context-menus-and-palettes/m-p/428210...
Greets, Dave
(1,646 Views)
Use the new "Double-click to Finish Wire" or click/right-click to get a menu. Almost as good as the old days, but not perfect. Or you can now write your own "Quick Change List" to maybe improve on that.
Certified LabVIEW Architect
(1,633 Views)
Hi Dave,
I noticed those items missing from the context menu almost immediately too. They can be enabled again with PopupMenus.ElevateCreation=True in labview.ini
(1,604 Views)
I found (well, for me as good as before): start wiring from the terminal, then right click.
Greets, Dave
(1,600 Views)
Also try out double-click for the default item. See Labview 2023Q3 changes
(1,590 Views)
