FP read digital
hi,
is there a way to get a digital value only if the value change for at least more than 2 seconds ( for example).
I don't want to get vlaues if they change too fast.
Thnak you
(2,998 Views)
Attached (LV8) is one method you could use.
Involves event structure and timeout manipulation.  Not sure how well you can hammer it into your code though.
I do not believe there is a "No code" way of doing this though.
Message Edited by Stradis on 06-06-2007 08:51 AM
Paul
(2,993 Views)
thank you,but it doesn't exactly fit to my wishes because it use a blocking loop : I have lot of digital inputs to read at 200 ms and have to make an operation if
predefined inputs values are ON  more than 1 s.
I expected to find out a solution to configure the DI module or using the "advise" function.
I will maybe use a cluster to store whe the input value start to be 1 and make a time calculation each time a read it again.
I hope to find a better solution.
Thank you
(2,983 Views)
If you are using a 653x board and ni-daqmx, you can use this change detection example
http://zone.ni.com/devzone/cda/epd/p/id/5015
Regards.
(2,962 Views)
