FP-2000, failed to deploy embedded VI, after VI runs fine from computer interface.
I have been struggling with the LV8.5 upgrade for 2 weeks now.  This seems to be one of the last hurdles.  I am recompiling my code for LV 8.5, from LV 8.2 and am not having this issue with each of my 6 FP-2000 controllers.  I get the VI running on my computer, then try to build the application for embedded installation.  Next I try to deploy the embedded application and invariably I get this message:
Deploying FP-2000 @0  (successfully deployed settings)
Deploying MPPT-Testbed  (successfully deployed target settings)
Deploying My Real-Time Application (failed to deploy)
Download completed with errors.
I have tried a number of build options, but will not deploy.
Any help would be greatly appreciated.
Bill
(2,613 Views)
Hi Bill,
Have you updated the software on your FieldPoint? You can do this in Measurement and Automation Explorer (MAX) by selecting your FieldPoint, expanding the tree and then right-clicking on Software. SelectAdd/Remove Software and make sure to install LabVIEW 8.5 for Real Time.
Let us know if this works.
Hillary E
(2,590 Views)
Yes, I have updated the embeded software.  I will uninstall, reformat drive and try the deployment once again.  I spoke with an applications engineer yesterday, who recommended that I mass compile the directory of my projects and check for VI conficts.  I have done this as well and was still having the deployment issue.
I have reinstalled all embeded software, the deployment worked.  I guess there was some issue with the software install?
Thanks for your help.
(2,585 Views)
Hi Bill,
It is possible that there is corruption when installing software. Hence, uninstalling and reinstalling can solve the problem. That looks to be the case this time.
Hillary E
(2,571 Views)
