FM DEMODULATION
Hello, i have done the FM modulation but i can't  recover the signal while demodulating ,i will appreciate any help
(6,499 Views)
I am sorry i forgot to mention the main problem ,during demodulation the signal gets attenuated  when i reduce : frequency deviation , carrier frequency and baseband signal frequency  but when they are high the signal seems fine , please help
(6,415 Views)
It seems there is no one qualified to answer my question ,i hope this vi helps people in future simulating FM modulation ,thanks to all
(6,354 Views)
Look in the Example Finder under FM. This is what I found. I really can't follow your VI, but it doesn't look like you are doing the mixing correctly.
mcduff
(6,347 Views)
the modulation part works ,it is the demodulation that is the problem
(6,332 Views)
Accepted by isa12
I can't reproduce your picture with your VI; the plots just show zero. From the bottom plot in your picture it looks like you are demodulating the message.
I did something similar awhile ago, on a FPGA, where I multiplied the modulated signal by Cos and Sin of the carrier frequency, low pass to get I & Q, then do the Arctan to demodulate.
Sorry I can't help.
mcduff
(6,329 Views)
after you run the vi adjust all the parameter like baseband frequency ,amplitude and so on ,you will see the plots
thanks for the advice it really helps
(6,324 Views)
