Extrating cursor value
I had a version with Demo mode.  I will put it back in.  I will reorganize a bit better and try the While loop.  If I still have problem, I will post it again.  Thank you.
Message 11 of 23
(3,259 Views)
To Prevent numerous loop runs, I would advice using an event structure with the 'Cursor Move' event, and the data change event.
Ton
My LabVIEW Ideas
Message 12 of 23
(3,257 Views)
I attached a demo VI of my project.  The VI generate an impedance and reactance plot on tap 3.  The Data are randomly generated.
I implemented the ActCrsr like suggested by Alain.  I can extract both Xs and Ys values of the cursors.  The two Xs should be equal and represent the frequency.
I also try to figure out how to implement the Event Structure like suggested by Ton, which I will like to do.
In the Event Structure;I set an Event for when the value of the cursor X (frequency) change value but how to make it work?  How to refresh the value ( I tried a While Loop but no success).
I will like also to have two other cases inside this structure that will execute if Inductive is True or Capacitive is True.  I tried to add case when Inductive is True but the only choice is when "Value Change"???
I put some code to calculate Xc and Xl.
My goal will be to display a drawing model of resistance in parallel with a capacitor or a resistance in parallel with an inductor.
Thank you again
Message 13 of 23
(3,233 Views)
Accepted by topic author fmethot
Message 14 of 23
(3,217 Views)
Alain,
...can you make it for LabVIEW 8.2?
Thank you
Message 15 of 23
(3,213 Views)
Message 16 of 23
(3,211 Views)
Bonjour Alain,
OK, I will never delete Timeout again.
...I don't see the values updating when the cursor is release?
Is the CASE 1 is functional as it is?
Message 17 of 23
(3,202 Views)
Hello François,
Can you place a break point on the wire between CursIdx and the case selector in the event state "XY Graph": Cursor Release"?
Just to be sure that the code passes there 🙂
As you can see in the three attached screenshots, the code is working on my PC with LV 8.5.
I know the cursor handling wasn't available in LV 7.1 😞
But I don't when it came available. Was it in LV 8.2 or later I don't know Smiley Sad Someone else?
I found a work around for LV7 version since I already used such cursor move stuff at that time.
So if you still encounter problems I can dig up that "old" software and post it also.
But first please try the breakpoint.
Regards
Alain
Message 18 of 23
(3,193 Views)
I am running on LV8.5 from another computer.  No change in the X cursor location???
Message 19 of 23
(3,187 Views)
Weird, strange 😞
I saw the breakpoint in your code.
Does the code halts at that point when releasing a cursor or not?
Message 20 of 23
(3,182 Views)
